PWD8 Hours?
Discussion in 'Plasma TVs Forum' started by dando, Nov 4, 2005.
  1. dando
    dando
    Just wondered if anyone knew how to check this panels hours? How do i get into the menu? Any info would be appreciated.
  2. SteveG
    SteveG
    Jan 14, 2003
    1,041
    London, UK
    +92
    Press and hold down the volume down button on the front panel and then press the status button on the remote three times quickly
    You then select the SD mode by UP and Down on the remote then press the action button on the remote
    PT is the cumulative Time for power on condition measured in hours
    WT is the power on counter.
  3. dando
    dando
    Thanks Steve. It is okay to do this isn't it, cos' I havn't seen it in the manual and I dont wanna damage the panel?!
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    its fine, just dont change any of the settings in the other hidden menus.
  5. dando
    dando
    Can't find status button on remote. :rolleyes:
  6. horsegun
    horsegun
    Aug 10, 2005
    69
    Bath
    It doesn't say status button on the remote but its the button on the top right hand side with a square looking symbol. Sorry I cant describe it any better but I am currently at work.
  7. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,498
    137
    Middle Earth
    +980
    The one to the bottom right of the joypad. Top left is N, top right is R and bottom right is a picture of a screen with a + sign in the bottom right, that is the status button.
  8. dando
    dando
    Cheers. :smashin:
  9. mk85
    mk85
    The above doesnt appear to be working. Has the code changed?????
  10. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Nope, it does work. Just make sure you don't have your hand over the IR sensor when pressing the volume button on the panel. Others have done so :D
