PWD7 problem
Discussion in 'Plasma TVs Forum' started by Pufz, Oct 20, 2005.
  1. Pufz
    Pufz
    Aug 8, 2005
    94
    11
    Reading
    +3
    I bought my panel about a month ago but only got it fired up about 4 days ago.. still in it`s box though.
    I`m a bit concerned with a dark bar, which goes across the full width of the screen, about an inch wide, at the top of the screen.
    I`ve only had the screen on for about 8-10 hrs in all.
    I`ve taken all the advice given and turned the contrast down to -25 and been running in a full screen mode.
    It is very noticeable when the panel is switched off.
    The bar is much darker than the rest of the screen.
    Any help or advice would be much appreciated.
  2. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    Check how many hours are on the screen,
    Hold on a mo and I'll get the instructions for how to do this
  3. vileda
    vileda
    Oct 15, 2004
    401
    here you go,
    "hold down both vol buttons on the fromt of the screen and then keep pressing the button under the on/off on the remote until it appears"
    There will be numbers for WT (watched hours) and PT (number of times turned on).
  4. Pufz
    Pufz
    Aug 8, 2005
    94
    11
    Reading
    +3
    Just checked.. 16hrs in total
  5. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    actually I think its the other way round PT= hours
  6. Pufz
    Pufz
    Aug 8, 2005
    94
    11
    Reading
    +3
    one says 16, the other says 17.
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    well its a new screen anyway so your dark bar is most unusual and I would contact your supplier
  8. vileda
    vileda
    Oct 15, 2004
    401
    Just testing, honest :rolleyes: I must check mine to see if I can take it out of running in settings :D
  9. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    :) the 'w' is just to fool you
  10. Pufz
    Pufz
    Aug 8, 2005
    94
    11
    Reading
    +3
    thanks mep.
  11. vileda
    vileda
    Oct 15, 2004
    401
    I think I can, WT=741 PT=2433 so that must be power on of 2433 hours
    I'd definately get on to the supplier about the dark bar
  12. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    i think you'll be safe now :)
  13. vileda
    vileda
    Oct 15, 2004
    401
    Mep, how much better would you say the PHD8 is than the PWD7 when viewing Sky?
  14. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    I wouldn't say it was any better at all to be honest vileda
  15. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    You're not talking about the border that goes right around the screen on the Pannies? I only ask 'cause you see it with the panel swicthed off! :eek:
    Bit of a cheek that they have the border as it reduces screen size! :mad:
  16. Pufz
    Pufz
    Aug 8, 2005
    94
    11
    Reading
    +3
    No.. definitely not the screen surround.
    It`s only across the top of the screen.
    Does the screen go lighter in appearance as it is run in at all ??
  17. vileda
    vileda
    Oct 15, 2004
    401
    Ring the dealer NOW and tell them that it's been faulty since you got it, they will be able to verify the number of hours on it and the only way you could have done this would to have put a static white screen on the bottom 90% of the screen which is not likely.
    You may find that the display evens up over time but do you want to tak e the risk, get dialling and get them to check it out.
    P.S. it's an excellent screen so I hope you get it sorted.
  18. Pufz
    Pufz
    Aug 8, 2005
    94
    11
    Reading
    +3
    i`ve spoken to the retailer who have contacted Panasonic.
    Because it`s over 28 days old it might have to be sent back for repair rather than an exchange panel - which I don`t want.
    Waiting to see what Panasonic say now.
  19. vileda
    vileda
    Oct 15, 2004
    401
    I shouldn't think they'd be able to fix it anyway, possibly replace nearly everything apart from the Bezel but not repair it.
    When they take it away I hope they leave you a replacement to watch.
  20. vileda
    vileda
    Oct 15, 2004
    401
    Sorry, missed this bit, It could be the proctive layer de-laminating (think that's the term) in which case they should just give you a new one. Did they offer to come and inspect it before taking it away?
  21. Pufz
    Pufz
    Aug 8, 2005
    94
    11
    Reading
    +3
    The retailer has just got back to me saying they were trying to get hold of Panasonic all afternoon and have only just discovered that they have moved locations.. :mad:
    They can`t get hold of them now until Monday.
    The screen hasn`t been taken away.. yet
    Apparently somebody will come and look at it and we will go from there.
    Wait and see time..
    Hopefully will just replace it with a new one.
