PWD7 or PWD8
Discussion in 'Plasma TVs Forum' started by 999dom999, Nov 2, 2005.
  1. 999dom999
    999dom999
    Aug 10, 2005
    The price difference is about £300, is the PWD8 worth the extra dosh?
    HD I'm not bothered about.
    Thanks for any advice :thumbsup:
  2. steve_peak
    steve_peak
    Oct 3, 2005
    101
    pwd8 can take component signal through its on board vga terminal so no need to buy a component board. Use of the HDMI board in it..you may not be bothered about HD sky but what about using hdmi input for other sources, dvd, xbox360 etc.
    Other than that i'm not sure, but i have a pwd8 and can vouch for the fact that it is an excellent panel!
  3. 999dom999
    999dom999
    Aug 10, 2005
    Are you running component through the on board vga on your screen? Is there any difference in quality compared with a component board and would I need one of those JS jobbies to do it?
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    with the 8 series you don't need a js box to connect component to vga (you do for scart to vga) I have connected by both component to component board and component to vga with my dvd and don't think there is a difference.
    The PW7 is a great screen but for the sake of £300 I would go 8 series, as mentioned above you may be interested in some form of HD in the future, it a very small price to pay for an element of future proofing.
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,633
    Norwich
    +1,065
    Is it £300 cheaper when you sit down and work out everything you need?
    The PW8 can be had for a good price in the special offer secion of this forum with stand etc. included.
  6. 999dom999
    999dom999
    Aug 10, 2005
    I'm new to this forum and I'm not sure where the special offer section is? I looked under Plasma Power Buy Special Offers but this just has Wall mount brackets am I missing something? :confused:
    I will probably go for the PWD8 its right HD maybe a consideration in the future.
    So to use the vga port for component its just a cable?
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
  8. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Yep, just what they call a VGA breakout cable, with a VGA socket at one end, and 3 cables at the other. Here's and example. Also check out the AVForums AV-Links section here for various website where you can buy these sort of cables.
    Andy
