PWD7 cantilever bracket?
Discussion in 'Home Cinema Buying & Building' started by clarky78, Aug 1, 2005.
  1. clarky78
    clarky78
    Nov 8, 2004
    1,830
    Nottingham
    +38
    Can you get one to fit the 37" version? i only have seen them for smaller, lighter tv's. It needs to fit across a corner, not flat to the wall.
  2. clarky78
    clarky78
    Nov 8, 2004
    1,830
    Nottingham
    +38
    no??
  3. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Quick answer... Yes.
    I have seen them in the flesh, but they are expensive (cant remember who makes them).
    It may be cheaper to bridge the corner, maybe with 3 x 2"/4" and then mount a wall bracket on. If you use 45degree metalwork (roofing supplies @ B&Q etc.) and big bolts!!! But all depends on how you want it to look & how far into the corner you want the screen to be...
    I'll try and dig out a link for the brackets anyway...
    Gareth.
  4. clarky78
    clarky78
    Nov 8, 2004
    1,830
    Nottingham
    +38
    Thanks, it's not really viable for builing across the corne, so its gotta be a canti bracket,r
