PWD7 - can I drive VGA i/p from SCART RGB with conversion cable?
Discussion in 'Plasma TVs' started by alanfcross, Mar 4, 2005.
  1. alanfcross
    alanfcross
    Does anyone know if it is possible to drive a SCART-type RGB signnal into the VGA port on a PWD7 with just a conversion cable? Wll it accept H on the composite feed, and V from blanking? Or is the amplitude too small, or the timing wrong? If anyone has tried this, what is the wiring of the conversion cable, or are these commercially available?
    Just want to try this before forking out on a JS converter.
    TIA.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the JS tech RGB>VGA does that for you but there are cable solutions from QED and Keene have a search for syncblaster
  3. sldt
    sldt
    The web sites mentioned towards
    the bottom of this link go into this in detail
    [LINK TO EBAY SALE REMOVED BY MODERATOR]
  4. sandstheman
    sandstheman
    Jan 6, 2005
    526
    28
    +46
    So if i've got it right, the board being sold on that auction will let me connect the componentout from my amp to a PW7 using a component to vga cable :confused:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    no it is an RGBHV/RGBS/YUV board with a 15pin D-sun to connect RGBscart still need a sync seperator QED and Keene make them: But the JS box is better. (the cables are powered and have really no advantage over JS box except price.
  6. sandstheman
    sandstheman
    Jan 6, 2005
    526
    28
    +46
    If it's a YUV board then thats what my amp outputs, the component outs on it are labelled Y,Pr,PB (Denon 3802), which is just a different notation for YUV, i think.
    Or is there something that i'm just not getting that means it won't work :confused:
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    You are correct YPbPr will work into an extra VGA board, (that auction is expensive tho AV-sales Additional PC slot £67.56) so at £50 already with £10 P+P and while to go...............
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    [EDITED BY MODERATOR - a bit OTT hornydragon, the report to moderators was enough]
  9. sandstheman
    sandstheman
    Jan 6, 2005
    526
    28
    +46
    Ah thank you, that makes things clearer now, my only reason for leaning towards a PW6 over the 7 was the ability to connect my compnent out to the vga input, but thats irrelevant now.
    67.56 is good price, but can only get it with the purchase of a screen, and PW7 is cheaper elsewhere
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    add up all the bits you want inc delivery boards warranty etc then compare the 123 price with 2 more boards and 3 yr warranty is about the same aAV-sales for the same (and you get the better spec PWD7 from AV-sales rather than the discontinued PW7)
  11. sandstheman
    sandstheman
    Jan 6, 2005
    526
    28
    +46
    Hmm interesting :thumbsup:
