Pwd6 With External Speakers - Help!
Discussion in 'Plasma TVs' started by Upgrade King, Apr 12, 2005.
  1. Upgrade King
    Upgrade King
    Aug 8, 2004
    16
    I am currently waiting for my new amp to arrive and i decided to attach my front left /right Castle compacts to the screen via the spring clip terminals on the back - i have not been able to get any sound to come through them, any suggestions please?
  2. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    What input did you use? the built in one next to the VGA or one on an input on a card?
    Have you turned the volume up using the remote / front buttons
  3. Upgrade King
    Upgrade King
    Aug 8, 2004
    16
    It is the VGA to Scart that goes to the sky + box
  4. Mep
    Mep
    Dec 25, 2004
    9,550
    +471
    have you connected the audio to teh js box? (the red white stereo cable)
  5. Upgrade King
    Upgrade King
    Aug 8, 2004
    16
    Mep - i don't have a js tech box, i have a vga to scart syncblaster cable, are you saying this does not carry sound?
  6. Mep
    Mep
    Dec 25, 2004
    9,550
    +471
    no it doesn't..do you have sound input on one of your terminal boards?
  7. Upgrade King
    Upgrade King
    Aug 8, 2004
    16
    Only have the component board, it has a red and white input next to the 3 component inputs (i asume these are audio left/right) i've connected a stereo interconnect to the stereo inputs on the sky box and still nothing
  8. Mep
    Mep
    Dec 25, 2004
    9,550
    +471
    if you switch to that input, i know you wont get picture, but do you get sound?, i guess the sound input realates to the input board only....shame its not the dual component / composite as you could have used svideo til the amp comes
  9. Upgrade King
    Upgrade King
    Aug 8, 2004
    16
    Just discovered that! Many thanks for all your help anyway, guess i will have to wait a few more days
  10. Mep
    Mep
    Dec 25, 2004
    9,550
    +471
    you'll have to use subtitles :)
