PWD6 VGA input question
Discussion in 'Plasma TVs Forum' started by RossC, Aug 18, 2003.
  1. RossC
    RossC
    Feb 13, 2003
    144
    Quick one - does the VGA input now support all screen modes as it didn't on the 5 series (having a very reduced set of modes available)?
    RC
  2. GAmbrose
    GAmbrose
    Jul 5, 2003
    980
    43
    Essex
    +177
    It now supports RGB and YUV if thats what you mean.
    Gary A
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,968
  4. BertG
    BertG
    The PC port reports this
    Timing characteristics
    VESA GTF support............ Not supported
    Horizontal scan range....... 29-94kHz (est.)
    Vertical scan range......... 43-88Hz (est.)
    Video bandwidth............. 2550MHz (est.)
    Timing recommendation #1.... 1366x806 at 57Hz
    Modeline................ "1366x806" 86.710 1366 1398 1579 1792 806 806 841 844 -hsync -vsync
    Timing recommendation #2.... 852x480 at 60Hz
    Modeline................ "852x480" 34.010 852 880 1016 1072 480 480 540 529 -hsync -vsync
    Standard timings supported
    640 x 480 at 60Hz - IBM VGA
    640 x 480 at 67Hz - Mac II
    640 x 480 at 72Hz - VESA
    640 x 480 at 75Hz - VESA
    640 x 480 at 85Hz - VESA
    720 x 400 at 70Hz - IBM VGA
    720 x 400 at 88Hz - IBM XGA2
    800 x 600 at 56Hz - VESA
    800 x 600 at 60Hz - VESA
    800 x 600 at 72Hz - VESA
    800 x 600 at 75Hz - VESA
    800 x 600 at 85Hz - VESA
    832 x 624 at 75Hz - Mac II
    852 x 480 at 60Hz - Panasonic
    1024 x 768 at 43Hz - IBM 8514a
    1024 x 768 at 60Hz - VESA
    1024 x 768 at 70Hz - VESA
    1024 x 768 at 75Hz - VESA
    1024 x 768 at 85Hz - VESA
    1152 x 864 at 85Hz - VESA
    1152 x 870 at 75Hz - Mac II
    1280 x 960 at 85Hz - VESA
    1280 x 1024 at 75Hz - VESA
    1360 x 765 at 60Hz - VESA
    1366 x 806 at 57Hz - Panasonic
    1600 x 1200 at 75Hz - VESA
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,219
    The Borders
    +2,933
    RossC
    Not got my PWD6 here today but from memory the PWD6 adds in either the 'zoom' or the 'just' mode that you didn't get with RGB on the PWD5; though remember there's no auto switching on RGB.
    Regards
    Joe
  6. RossC
    RossC
    Feb 13, 2003
    144
    Thanks everyone - aspect ratio indeed, so much better put by Gordon!
    No auto switching presumably means it doesn't resize itself on the 'auto' setting?
    RC
  7. lmccauley
    lmccauley
    Oct 24, 2000
    3,430
    Newcastle
    +268
    With the VGA port you can set it to 4:3, 16:9, Zoom or Just. There is no Auto setting for the VGA port.
    Cheers,
    Liam
