PWD6 - peak limit????
Discussion in 'Plasma TVs Forum' started by robbleiper, Mar 9, 2005.
  1. robbleiper
    robbleiper
    Dec 31, 2004
    1,005
    Newport-on-Tay
    +37
    Currently tinkering with DVE disk. Am unsure whether to set PEAK LIMIT on or off before adjusting other settings???
    Can anyone offer any help with this!?!
    (Have just run in for first two hundred hours now...)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    do not use peak limit it clips the top white level calibrating properly means you dont need it its more for fixed data installs to minimise screen burn!
  3. robbleiper
    robbleiper
    Dec 31, 2004
    1,005
    Newport-on-Tay
    +37
    Also, have concern about turning WOBBLING option off. Want to calibrate screen to 0% overscan but then wobbling would be visable.... anybody suggest what they did???
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    there is not much point in running 9% overscan (yes i do but there is no good reason for it) turn wobble off while you calibrate and back on afterwards if watch alot of logo channels etc..........
  5. robbleiper
    robbleiper
    Dec 31, 2004
    1,005
    Newport-on-Tay
    +37
    Thanks for posting back so quickly HD....(again)
    CHEERS!!!
