Can anyone help me with the appropriate code to control my PWD6 from my One For All Kameleon remote? I've done several searches and found references to people who are doing this - but can't find the actual code number... Anyone know what it is?
i used one of the codes from the instuction book if you not got will find it for you only switches on and volume cant get bightnes and contrast to work yet but been told can learn of my orginal remote hope this helps ps try thes 0650 1650 0108 0226 0361 0367 0516 0037 0556 0163 0548
As it can actually learn code, you could go one better if a friendly forum member lives near you and has a well programmed pronto. You could learn the discrete codes from the pronto, much better for incorporation into macros.
Got it working using 0650. This enables the power, menu and 16:9 keys (probably volume and mute too - but I have those shifted to another device) I had to 'learn' the Setup, Picture, Up, Down, Left, Right, OK and Return keys - but it's working great now! Not sure discrete codes would help me - everything is fed through a JS RGB->VGA box so I don't need to be able to switch inputs. Might be handy if there were discrete codes for Aspect Ratios though - I only ever really use 16:9 or Just. I'll probably buy a Aspect switch box from av-sales when my bank account balance is a bit healthier though! Thanks for your help.
There are discretes for aspect, and power on/off. There are no discrete input codes apart from the PC one, which obviously is on the original remote.
The manual for the PW6 indicates that you can select a specific input via the RS-232 port. Is it possible to convert an I/R signal to a RS-232 command? Would any of the X10 boxes do it perhaps? Thanks
There are indeed devices to do this, not x10 though, it's a bit more complicated than that. Try a search on the net for it, you will turn up quite a few options.
