pwd6 noobie advice needed
T
turbo555
i need some help with connecting it up i have a ps2 and sky+ and was going too run these through my sony dvd recorder which has a component output however the display has the vga connection only do i need too buy the panasonic component board or is there another or better way of connecting
any advice would be great as there is no point throwing money at cables until i know what are the best connections
thanks in advance for any replies
dean
stevelup
You can connect component video directly to the VGA socket on the PWD6.
All you need is a VGA>3 x Phono cable.
Steve
T
turbo555
thanks steve this seems like a very easy option will there be any quality loss running all the cables through the dvd recorder and does anybody know where i can get a good qualty VGA>3x phono cable
stevelup
I can't really answer your first question. If you post and say what the model number of your DVD recorder is, I'm sure someone else will comment.
Here's the VGA to Component cable:-
2M
5M
10M
Steve
