pwd6 connections
Discussion in 'Plasma TVs Forum' started by srbwilson, Jan 18, 2004.
  1. srbwilson
    srbwilson
    Jan 6, 2004
    298
    please help! i know that this has been discussed a lot in this forum but it needs clarifying for me. i have a pana pwd6 with the bnc component board, scart board and the s video composite boards. i need to connect a freeview box, HK dvd25 prog scan dvd player and an xbox. i understand the best way to connect my dvd player is via a component cable and the freeview box via rbg scart, but that leaves me with just svideo for the xbox, which im a little disapointed with as i currently run it (through my crt tv) through an rgb cable. can i buy a cable to feed either the freeview box or xbox into the vga on the screen? and if so what signal will this be?
    any advice would be most welcome.
    thanks
  2. jmack
    jmack
    why not get a quintro scart switch box you can plug 3 or 4 rgb scarts in to it at once then 1 scart cable to plasma
    try www.keene.co.uk
    you can get a rgb to vga for freeview or xbox. www.rgbtosvideo.com
    look for rgb to vga
    #there was one on ebay few days ago.
  3. jmack
    jmack
  4. jmack
    jmack
  5. jont
    jont
    Apr 8, 2002
    4,243
    near Aylesbury
    +545
    Or could you put the RGB scart from the xbox on a pass through on your freeview box or dvd player (assuming they have one ...)
    Jon
