pwd6 component board problems..help
Discussion in 'Plasma TVs Forum' started by MD_London, Aug 22, 2005.
  1. MD_London
    MD_London
    Sep 8, 2004
    45
    I have a pwd6 and have recently bought a bnc component board and bnc to rca cable from av-sales. I plugged in my dvd player using the cable but nothing shows on the screen. I have checked the the cables are in the right coloured connectors.
    I have set the screen to component input and the indicator in the top right hand says "component" and I have changed the settings from RGB to component....am I missing something or have I got faulty equipment
    Please help
  2. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    have you set your dvd player to output a component signal. this is usualy from the setup menu. some like toshiba have a switch on the back to choose between scart and component
  3. MD_London
    MD_London
    Sep 8, 2004
    45
    Thanks for the quick reply
    no I haven't tried that. The DVD player is a Denon...I will check that
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    if it's a denon it could be a software issue as with some of the version 4 software multi regoin versions you can't get a picture withe the denon set to prog scan but it works when set to interlaced...updating to version 8 sorted this out for me with my 2910
