PW9308 to Aventos?
Discussion in 'Televisions' started by Chris_D, Jul 2, 2003.
  1. Chris_D
    Chris_D
    May 11, 2003
    30
    After pixel+ artifacts driving me round the bend im thinking of changing from my Philips 32PW9308 to a different make and have heard a lot of good things about Loewe. The two models ive seen which im thinking of exchanging for are the Aventos or the Vitros. Could anyone tell me what the difference is between the two models in regards to picture quality and how much of an improvement over the PW9308 il get?
  2. leeoh
    leeoh
    Nov 11, 2002
    111
    16
    Buckinghamshire
    They are much the same picture wise. Main difference is the Aventos is cheaper by virtue of using cheaper plastic and simpler design. I went for the aventos and am very happy with it. It will be a big improvement over the Pixel Plus not just in picture, but also geometry, no buzzing power supply, no famous vertical lines, etc, etc.
