Pw7 - Worried!
Discussion in 'Plasma TVs Forum' started by Stumpywhu, Mar 1, 2005.
  1. Stumpywhu
    Stumpywhu
    Nov 30, 2004
    373
    +11
    My PW7 has now done approx 250 hours and am delighted.
    BUT I have started to notice a slight horizontal shift then vertical then horizontal (the other way) etc etc....
    I have the screen savers on so am hoping someone will tell me that this is the screen saver in action.
    Is it that its always done this and I havent noticed before or has it developed a fault?
    Any advice appreciated.
    Thanks.
  2. hermanmunster
    hermanmunster
    Dec 23, 2004
    499
    Somewhere sunny and warm...I wish
    +24
    Yep, it's the screen saver. You've probably not noticed it before, only seems noticeable on PC display to me. Can also be seen when there are channel logos as they are usually close to the edge of the screen any movement is sometimes noticeable. :)
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    turn off wobble
  4. Stumpywhu
    Stumpywhu
    Nov 30, 2004
    373
    +11
    Thanks gents.
  5. adymartin
    adymartin
    Jan 27, 2005
    130
    16
    i'm stunned that you haven't noticed this before :D
    you should be past the point of looking for things to go wrong by now mate. :thumbsup:
    just get on with enjoying your tv. having owned two techwoods, i'm constantly paranoid that something is going to go wrong with my panny. 60 hours into it's life, i'm looking forward to the day when I have recovered completely from my plasma paranoia!! :D rehabilitation takes time..... :rolleyes:
  6. Peabo
    Peabo
    I know the feeling! I used to own a Samsung which broke with several vertical lines of dead pixels appearing. The replacement broke too with the same problem and both after less than 2 weeks of use! I now have a PWD6 and I'm still nervous about one of those horrible lines appearing! Oh the trauma!!! :eek:
