PW7 VGA Input
Discussion in 'Plasma TVs Forum' started by Bobby_Dazzler, Jan 19, 2005.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi all
    If I use the rgb to vga convertor by js technology will the picture aspect be ok as it would be with a normal scart or will i have to keep changing in manually?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    need to change manually or buy the aspect changer box (does it for you)
