PW7 versus 42PE50
Discussion in 'Plasma TVs Forum' started by empirix, May 24, 2005.
  1. empirix
    empirix
    Apr 19, 2005
    57
    9
    I am about to take the plunge at long last. Had just about decided on a PW7, then I am told about the Viera 42PE50. For the relatively small cost difference, which one should I go for ?
    Anybody done a side by side test setup properly ?
    And then of course theres the 42PV500B ... but I just can't justify spending more than £2K for high-def at the mo ...
    help !
