PW7: Using VGA Connection?
Discussion in 'Plasma TVs Forum' started by JamesL, Dec 28, 2004.
  1. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    I currently have a PW7 with three Terminal Boards (HDMI, Component RCA and Scart) - however I now need to connect an extra Scart device. I assume the labbelled 'PC In' connection is, as it looks, a VGA connection - will a Scart to VGA converter work via this? It would be connected to a DVD recorder (Panasonic HS2) which in turn would be fed a Sky picture. Can anyone recommend a model that won't break the bank?
    Many thanks!
  2. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    RGB>VGA will work excellently mate JS BOX is top of the Tree quaility wise.....SKY>HS2>JS BOX>Panel VGA but need to set it all up on RGB in and outs
  4. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    Excellent. Thanks for the replies/help!
  5. elliott-cardiff
    elliott-cardiff
    Aug 22, 2004
    53
    A related question, I am planning on feeding several signals through a JS RGB > VGA Converter, One of them will be my video which only outputs a composite signal. Will the JS box effectively pass-thru this signal. I'm not looking for it to improve the output from the Video just to let me watch some of the films I've taped over the years.
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    No, won't work. This is fine via the scart board, not via any VGA converter. You could do it with a scaler, but that's a bunch more cash.
