Pw7 Settings
Discussion in 'Plasma TVs Forum' started by mafri1972, Jan 12, 2005.
  1. mafri1972
    mafri1972
    Ok, my toy has finally arrived from AV sales, and I've got a couple of questions.
    1. I know, I know, I know that I should change the contrast settings, etc. in accordance with my own taste and circumstances - but the factory settings were so apalling I thought it might be interesting to see what other people use. I've left things pretty much were they are, apart from the contrast which is now 17 (prev. 30!)
    2. The desktop stand from AV sales - seems I have a choice of mounting higher or lower. I went for higher, bearing in mind cabling, etc. but I'm now wondering whether to change it. Any thoughts....?
    Martin
  2. blackmanalishi
    blackmanalishi
    I'd be interested to know what others use too - mine's currently set to 5 on everything, and "Normal" picture type. It's a tiny bit darker than I would probably go for, but certainly prepared to live with it within the first 200 hours (am at 100ish now)
    re the stand - get a wall mount. Frees up loads of space in the room and you feel like you're in a futuristic film! :D
  3. PTG
    PTG
    Mafri- suggest you reduce contrast and brightness, make sure it is in normal mode for the first 200hrs before you start making the panel shout.
    Ref other peoples settings, this can vary from panel to panel, so I would go for one of the set up disc's available after she's run in. :thumbsup:
    Enjoy.
  4. blackmanalishi
    blackmanalishi
    Thanks PTG. I've got DVE ready and waiting for when I hit 200 hours, I was more concerned with feeling confident with the settings I've picked during the run-in period...
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    have my PW7 due next week from av sales and also ordered dve form piero for use after 200 hours is up :)......does dve come with plenty of instructions for the hard of thinking? :)
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    dve needs a good watching on your own (no kids dogs mates) is boring but worth while (nightamre to navigate tho)....... what i do is RUN a couple of DVE patterns and then knock the settings down another 2-3 (AMBIENTLIGHT!!!!) remember Abientlight makes a huge dofference to PQ and the pannys have different modes, no good setting cinema up if missus knocks it into dynamic first time she picks it up............and you dont notice......... adjust all modes.......
  7. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Time to buy a white cane and some dark shades if that's the case :p and possibly a guide dog :D
    S.
  8. PTG
    PTG
    Keep logo chennel viewing to a minimum if poss, make sure the picture fills the screen and as long as the picture is watchable and not screeming at you it should be fine. Once you hit 200 do as horney say's and spend a bit of time calibrating.
    Must admit though, after you have watched your panel with reduced brightness and contrast for 200hrs-it's a sight for sore eye's :) :smashin: have patience blackmanalishi "god that word is a pain!" it will be worth it in the end.
    PTG
  9. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    Life's never easy is it! :)
  10. mafri1972
    mafri1972
    Ok, I've played for a while, and 3 words come to mind. Stunning, stunning and stunning.
    I'm impressed! If anyone is struggling to make the decision, just do it and get a PW7 with decent component inputs - you won't be sorry.
    One thing I have noticed, though, is a slight graininess when looking at blacks (bars at the top and bottom of DVD's, etc.) is that something in my settings/cable quality or something else? It's minor, I'm knit-picking as you can only see it if your within a foot of the screen - but it would be nice to know!
  11. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    have already done so my friend....just awaiting d-day!
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Tis dithering try turning brightness down a bit and contrast........
