Pw7 Service Menu
Discussion in 'Plasma TVs Forum' started by Baron Von Doom, Apr 29, 2005.
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    Is The Service Menu The One Where You Hold Down Volume And Push Button Under Power Three Times?
    What Do The Options In This Menu Do?
    What Does Each Option Stand For?
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes it is.....but you don't want to be messing in there if you don't know what you're doing ...interesting one is the sd option...shows you WT= times turned on and PT = hours viewed
  3. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    Thanks. Do You Know What The Other Things In There Do. I Wont Go Changing Them But Interesed In What They Are
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    no...i've always been too scared to try :)
  5. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    quite rightly too! You can do serious damage if you don't know what you are doing. Not least, if you get into the wrong part of the service menu and start "experimenting" your remote will cease to control the plasma and then you will be well up the creek!
  6. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    Ok Thanks For Replying Will Leave Will Alone Then
  7. dilsher
    dilsher
    lol..Piers is so so right! Dont touch those se5rvice menus man..Liam went whizzing thru em like knife thru butter. But all I saw was funny looking lines and boxes and graphs and alien spaceships. In other words its like being in the Matrix in those menus.
    Leave it to Piers or Gordon or a decent installer i say, unless you do know wot you are doing. My new setup was basically plug and play cos Liam had done all the hard work wiv settings before installing. I dont have to touch the remotes now - except to switch on and off and change the input.
    Good innit??
    Dil
  8. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    thanks. will def not touch menu. Picture is good enough any way.
  9. dilsher
    dilsher
    coombes mate..its Ok to mess wiv your USER menus but not service menu!
    lol..
  10. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    i know already messed about with them
