Pw7 + Scht1500 Home Cinema
Discussion in 'Plasma TVs' started by Pogue, Mar 19, 2005.
  1. Pogue
    Pogue
    Mar 16, 2005
    15
    I was thinking about buying this setup (Panny PW7 + SCHT1500) as it seems to do everything I need.
    SCHT1500
    Would it be ok to connect the SCHT1500 to the PW7 using a TY-42TM6AB (BNC Component board) then connect my Sky digibox to the SCHT1500 using a scart ?
    Does this system look ok ? is there anything I have missed ?
    Also why is the TY-42TM6AB BNC Component board (£85) so much cheaper than the TY-42TM6Z RCA component board (£152)?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    should be fine but have a look here for better performing audio! http://www.avforums.com/forums/showthread.php?t=154292 add Panny E85/95 and Pioneer VCXS402 with Caton Speakers, it will do more than the 1500 and sound better!
    BNC is cheaper as its from Panny business sytems not consumer and is a less common connection for HC than RCA but IMO BNC is better!
