PW7 Scart Problem
Discussion in 'Plasma TVs Forum' started by maffup, Jun 6, 2005.
  1. maffup
    maffup
    A have a problem with my PW7, when I connect anything to the scart terminal board the picture scrolls but the vga via js converter works fine.
    Does anyone have any ideas?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    scart lead or board not properly seated sync signal is "off"
  3. maffup
    maffup
    Sorry to be stupid HD but what d'you mean sync sig is off how do I turn it on?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no i mean that the poor contacts somewhere are causing the sync signal to break up try removing and re-inserting the scart board
  5. maffup
    maffup
    Thanks HD I'll give it a try.
