pw7 scart board
Discussion in 'Plasma TVs Forum' started by Baron Von Doom, Jun 7, 2005.
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    Got scart board at weekend. got sky pluged into via b tech scart switcher. When the pans from side to side it seems to distort slightly. the only way it can be described is it goes very slightly wobbly like those fairground mirrors. its only slight but im sure its there.
    is this likely to be the board
    is it a known prob
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    what aspect ratio are you using?
  3. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    on auto at moment. would changing aspect make a diffence
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    try using 16:9 / 4:3 as appropriate i'm not sure how good auto is as i don't get that option using vga....but it sounds like the issue people when get using just which stretches a 4;3 image to fit
  5. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    is the component board much better picture than scart board with dvd or would vga converter be better and not use pc
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    component will be better than scart for dvd and i feel that vga is better for sky
