pw7 run in
Discussion in 'Plasma TVs' started by scotsman175, Mar 16, 2005.
  1. scotsman175
    scotsman175
    Oct 14, 2004
    571
    +9
    how do i find out how many hours my pw7 has been on for
    i think i got into service menu but didnt know what to do froom there?
  2. lupo
    lupo
    Jan 22, 2004
    100
    Berwick upon Tweed
    +6
    If you select the SD option.
    WT is the number of times you have switched it on and PT is the number of hours it has been on. I think I am correct. :)
    Kevin
  3. Novi
    Novi
    How do you get into the service menu and the SD option ??
  4. lupo
    lupo
    Jan 22, 2004
    100
    Berwick upon Tweed
    +6
    Hi Novi
    to get to the service menu, you hold down the volume minus button on the plasma and press the button underneath the power button on the remote 3 times. that brings up the service menu list. then just select SD
  5. Novi
    Novi
    thanks mate !!
  6. alanfcross
    alanfcross
    Excuse my butting in, lupo, but it doesn't seem to work on my PWD7. Do I have to be in a user adjustment mode before it will work?
  7. lupo
    lupo
    Jan 22, 2004
    100
    Berwick upon Tweed
    +6
    Hi alanfcross
    I have the PW7B... Maybe the PWD7 has a different way of accessing the service menu? I would assume all the 7 series would have the same way of accessing it.. But what do I know... I just got mine yesterday :)
    I might not have been clear with my instructions?
    you need to hold the minus button on the plasma ( not just press it ) while pressing the button on the remote.
    sorry it did not work for you.
  8. alanfcross
    alanfcross
    Yes, I did just that. Anyone else got the service menu story for the PWD7?
  9. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    may sound dumb (let's be honest..it is!) but when i first tried this with pw7 i realised my hand when holding the vol- button was blocking the IR sensor...doh!!..
  10. alanfcross
    alanfcross
    Some people are really dumb!! Wanna join my gang? I guess that was it! Thanks....
  11. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    :D see i'm not adverse to embarassing myself to help others :smashin:
