PW7 RGB Scart select
Discussion in 'Plasma TVs' started by JimmyA, Apr 10, 2005.
  1. JimmyA
    JimmyA
    I've read some threads that included difficulties over selction of the RGB input on the new Panny PW7. I've just set mine up and I cannot get any input from my Telewest Pace box other than s-video. The cable box is connected from the tv scart out (ie not the vcr out) via high quality scart lead to the panny scart board. I see from the forum that conversion to VGA is the preferred route but there is still no reason why I cannot select RGB on the set up menu? Under Set Up, the Component/RGB-in select option is grayed out confirming AV signal only.
    Telwest box is set to RGB. No other devices connected other than from Telewest VCR scart out via Scart to phono to receiver.
    I saw several threads that discussed this but not as simple a set up - I'm stuck. Any thoughts gratefully received.
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    because you can't feed component into the SCART board, so no need to give you the choice. nowt to do with no RGB input.
  3. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    sometimes it's just a case of taking the scart board out and reinserting it or trying it in another slot
  4. JimmyA
    JimmyA
    Thanks, take your point re no component in therefore no option required. However, it does seem to be a basic AV feed given the info displayed under the Setup/Signal menu - AV displayed in the right hand corner, rather than RGB.
    I've tried mep's suggestion also re slots/reinsert but no joy to date. Is there another source I can use to check if the screen is working correctly?
  5. rizingdamp
    rizingdamp
    pjclark is correct, I have pw7 connected to a humax set RGB and I also questioned the greyed out box its just that it doesent know any difference.
  6. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    have you got a dvd player or something else you can connect to the scart board....it may be a faulty board
