pw7/pwd7 help!!
Discussion in 'Plasma TVs' started by adymartin, Feb 9, 2005.
  1. adymartin
    adymartin
    Jan 27, 2005
    128
    16
    there are two deals available on avsales.
    one has a pw7 with a tuner unit(various inputs)
    the other is the specail offer pwd7 with free mount
    all i want to know, is what is the difference, the pw7 works out 100 quid cheaper for me, but i'm willing to pay the extra ton if the pwd7 is better.
    I know the difference is minimal between the two but is the pwd7 better for home use.
    if the picture will be the same then i'm partial to the media box offer as it offers me more input options for the future. but picture quality is king here so if the pwd7 is better please tell me.
    cheers.
    ( this is my last question before purchase!!.... hoooray!!)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    tuner box will work with either unit as long as they have the tuner input card (tuner is a waste of space mind.........) PWD is commercial unit and higher spec (none huge unless you use lots of PIP,PAP etc functions) but you need to work out you connectivity.there are loads of PW7 PWD7 threads going around at the moment.......
  3. adymartin
    adymartin
    Jan 27, 2005
    128
    16
    so there are no picture quality differences between the two?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    I havent seen them side by side to comment but if you pull the spoecs they are very similar....
