PW7 Picture problems with NTSC DVD's ?
Discussion in 'Plasma TVs' started by trent steel, Jan 28, 2005.
  1. trent steel
    trent steel
    Dec 21, 2004
    3,394
    West Yorkshire
    +767
    Hi people,
    After watching a R1 dvd on the PW7 last night I noticed that the black horizontal bars, top and bottom went a shade of red on light scenes and after 5 mins or so the red started to bleed in to the picture
    After turning the machine off and using another dvd player I got the same result
    This did not happen when I used R2 discs
    This never happened on previous crt tv
    Could it have anything to do with JS RGB - VGA convertor ?
    Picture is just about perfect on sky
    Any body got an idea where the problem may lie
  2. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    can you try another input component/scart to see if its still there..................think it maybe to do with the converter...................................i run sky with it......................but will try it with DVD and R1 discs to see if i get the same results
    cheers,tam
  3. Family Guy
    Family Guy
    Are you running the picture through an amp? Or is it directly connected to the plasma...? We have come accross this problem with PW7's that are being fed "upconverted" signals through an amp - particularly Onkyo...my Sanyo Z1 projector shows a yellow tinge on the right side of the screen but is fine when run direct from the DVD player.
  4. trent steel
    trent steel
    Dec 21, 2004
    3,394
    West Yorkshire
    +767
    Hi Guys,
    Tried the dvd hooked up to the scart socket on the plasma and the problem was solved
    :thumbsup:
