PW7, PANNY 7 - tint settings,input board?
Discussion in 'Plasma TVs' started by Dicky pw7, Apr 14, 2005.
  1. Dicky pw7
    Dicky pw7
    I recently got aPW7, really pleased with it, :thumbsup: everything seems to be fine
    (many thanks to the posts in these forums, glad to others have problems as well),
    however cannot seem to get the tint option to work on the menu, not even highlighted.
    Now, :rolleyes: I only have a scart input , budget dictated this at the time of purchase.
    Everything goes to a scart box, then to the screen. If I remove the scart box and connect straight to the screen (individually) it's the same.
    I only have phillips on digital box at present (if that signal makes a difference),
    So is it the signal or the input board?????????????????? :lease:
    Any views greatly appreciated
  2. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    i believe you don't get this option on rgb inputs.
  3. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    629
    It's greyed out on my scart input too, but is available on the component input, so I guess that's normal.
  4. Dicky pw7
    Dicky pw7
    Thanks, so if I get a component board, will the tint remove that glare I get sometimes?
  5. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    how would you connect digibox to component?
  6. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    629
    That I do not know (I'm sure there'll be someone along in a minute with such knowledge!), but I'd imagine that you shouldn't have such a glare anyway, so there must be another way to get rid of it.
  7. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Tint has nothing whatever to do with "glare". It alters the balance between red / green and only works on NTSC sources.
  8. Dicky pw7
    Dicky pw7
    In reading the instructions it said tint could be used for facial tones and sometimes if there's a scene with some one in bright sunshine, or studio lights there seems to be a "glare" from peoples fore heads. I 've tried altering the white balance etc, but I thought prehaps the lack of tint was the problem..
  9. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    sounds like solarisation...i think you should consider the js rgb to vga convereter
  10. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    or converter even :)
  11. Dicky pw7
    Dicky pw7
    Good point. :oops: Engage brain.
  12. Dicky pw7
    Dicky pw7
    Heard the name before , not sure what it is :blush:
  13. thegooseman
    thegooseman
    Cum on guys, leads any good? there is no visible difference between my Ixos 801(v.good lead) and and the best component lead.
    (Two equal sources, two seperate inputs to pw7, component and scart, pic in pic, direct comparison)
    infact I prefered the colour on the scart!! :eek:You can change the colour to suit but hey!!
    Seriously, Id get rid of the scart box, run everything through a dvd recorder, or something and get a good lead(like me) :smashin:
    That way you can choose component or SCART, and convert your signal if need be!!
    :thumbsup:
  14. Dicky pw7
    Dicky pw7
    I had wondered about cable :rolleyes:
    Thanks for advice , some things to think about :thumbsup:
  15. lisag
    lisag
    Jul 14, 2004
    5,558
    Essex
    +296
    Have you got a DVD player you can connect?
    If so, try the DVE disc first to callibrate, its only about £12 and you may get better results,
    However if this is a new panel you need to wait for the first 200 hours to pass before turning up the settings
    lisa
  16. thegooseman
    thegooseman
    If this is true, put the panel in cinema mode for the first month or two. :thumbsup:
  17. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,820
    2
    4
    137
    Garstang, Lancs
    +1,524
    Can the DVE disc calibrate normanl CRTs and my PC LCD monitor? (Haven't got a pasma yet) :rolleyes:
  18. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    look here mate
    you will also find some very useful docs on plasma connections
