pw7 owners! ty42tm6g possible bargain
Discussion in 'Plasma TVs Forum' started by c4lln, Mar 17, 2005.
  1. c4lln
    c4lln
    there is a buy it now ad on ebay flogging these for 46 +8 postage, will these work on uk screens, looks like a cheap input for sky or pc.
  2. hermanmunster
    hermanmunster
    Dec 23, 2004
    499
    Somewhere sunny and warm...I wish
    +24
    This will work and at that price it is very cheap. However it is normally used for daisy chaining in multiple display setups and I believe occupies 2 slots so depends on if you have the space. It also only goes into slots 1 & 2 so no Scart boards can be added either.
  3. c4lln
    c4lln
    i was worried about how many slots it occupied, so i did a bit of searching and it looks like it is only a single, but i could be wrong.
    chris
  4. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    These will work on UK screens, but be warned it is a two slot board, so only buy if you don't mind using up two slots.
  5. c4lln
    c4lln
    you are both right, it is a dual slot board.
    might be of use to someone though.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    and being sold by sldt a forum memebr................
  7. chienmort
    chienmort
    Only needs to go into slot 1/2 if you want RS232 loop through. So can be used in slot 2+3 with SCART or other board in slot 1. :clap:
  8. jwillans
    jwillans
    Can this be used in addition to the standard (supplied) VGA input on the PW6?
    I'd like to have my DVD going into one and tuner box into another.
    James
  9. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    782
    Amsterdam
    +15
    and if one buys these one would also have to buy a lot of additional cables ? if I want to buy this one and watch DVD with component , and a tuner with SCART and also the XBOX, PS2 and GC I don´t think that it would be a good idea to buy this, would it ?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    david you need more than a terminal board, you need a video swicth (suggest a 4-1 component switcher for XBOX,PS2,GC and DVD, connected to a component board, and either scart or JS RGB>VGA for tuner......
  11. delaxm
    delaxm
    Can someone please tell me what RS232 loop through is - thought RS232 was a sort of old computer interface
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    RS232 is serial data (plasma can be controlled by RS232 in stead of IR very usefull for commercial installs)
  13. sldt
    sldt
    I've been away for the weekend, but all the above are correct, jwillans hope your board has arrived, just out of interest does anyone know if the component signal is fed any differently via the TY42TM6G to a standard component board?
  14. jwillans
    jwillans
    sldt - Yes the board arrived on Saturday but I've only just collected it from the post office today. Many thanks for the quick delivery. I'm looking forward to trying it out after I get back from France in a couple of weeks.
    James
