PW7 or KDEP37SXQ
Discussion in 'Plasma TVs Forum' started by MPBayless, Oct 4, 2004.
  1. MPBayless
    MPBayless
    Undecided between the two. I have read all the threads about ALIS panels but still unclear.
    Obvious differences :-
    Panasonic - £2200
    42 in
    No tuner or Speakers (not a problem)
    Sony - £2700
    37in
    ALIS panel
    I understand that Panasonic screen is more suited to the input signal rather than the Sony which pre-processes the signal before display.
    However, Panasonic cannot handle as many different input type signals as the Sony ?
    Sony good for static pictures, Panasonic good for moving pictures ?
    Higher contrast on Sony due to higher number of pixels ?
    I need someone to summarise why Sony will not be better picture.
    Which gives better picture quality and why ?
  2. Tonester
    Tonester
    Never heard of that Sony model - you got a link?
  3. FEBABE
    FEBABE
    I think you've got some of your pros and cons the wrong way round. Either way you'll not find many fans of ALiS on here.
    Best thing to do is to go to your nearest Curry's, stand the distance you will be viewing from, look at the two side by side and let your eyes tell you which has the best PQ. I've spent hours in there....
