pw7 js vga connection probs. pls help!
Discussion in 'Plasma TVs' started by First-Timer, Apr 30, 2005.
  1. First-Timer
    First-Timer
    Got my JS converter and vga list today off the classifieds from one nice gent. Can't get a picture though! :(
    I have a telewest pace box from which i am ouputting a scart into the converter and a vga cable from the converter to the plasma. Cant work out if it is the settings on the plasma or the telewest which is the problem.
    Pls help as I am dying to watch football focus!
  2. ukdan
    ukdan
    Feb 16, 2005
    1,124
    swindon
    +84
    Is there a setting on the pace box to enable RGB output?
    You wont get a picture if its not
  3. First-Timer
    First-Timer
    yes there is i believe - RGB or composite - but i cannot get a picture up on screen to look at or change it anyway.
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    There are no settings on the plasma to help, it is telewest. You have either not got RGB enabled, or you are connected to the VCR scart, which only outputs composite, regardless of settings.
    No other TV in the house? You need to borrow a portable or something I'm afraid.
  5. First-Timer
    First-Timer
    will go and try the 15" now. ta.
  6. Educated Guess
    Educated Guess
    Dec 8, 2004
    1,459
    63
    +107
    And remeber of course that scart is directional, so make sure the lead is the right way around.
  7. First-Timer
    First-Timer
    nice one! changed the settings on telewest from composite to rgb on the 15" and bob's your uncle!
    B***dy snooker on now though - missed footy focus.
  8. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    You just can't please some people :D
