PW7 help
Discussion in 'Plasma TVs Forum' started by scullmeister, Oct 25, 2004.
  1. scullmeister
    scullmeister
    Jan 29, 2004
    22
    Ok here go's
    bought pw7
    have a dmr e55 component out
    have a sky +
    have an amp
    ok connect e55 to component board pro scan on great :)
    connect sky+ to e55 :lesson: will it send rgb signal
    also how will if fair against the js rgb to vga converter
    is there a bifference between rgb scart board and converter
    biggest thing that sprung to mind lip sync from sky+ when watching a movei(5.1) as the video has to go through the e55 and the audio from the sky+
    any ideas :lease:
  2. Davej50
    Davej50
    I have exactly the same kit, but rather than sending Sky+ through the E55, I am using the RGB-> VGA converter. I have tried sending Sky+ through the E55 but I found the picture wasn't as sharp. I guess it depends on how fussy you are but my argument was that I'm spending that much on a TV, I want it to be the best it can.
    I'm really pleased with the setup that I have, however I don't know if there's any getting around the lip-synching issues. I have it quite a lot, more noticeable on BBC1 than anything which I found surprising. I have set the distance on my speakers to maximum and that seems to have made it a little better but like I said, it doesn't do it all the time anyway. I would imagine (although I'm not an expert!) that sending the Sky+ signal through another unit before getting to the TV may make it worse?
    Hope this helps,
    Dave.
