PW7 & HDMI Board
Discussion in 'Plasma TVs' started by dvdchild, Jun 30, 2005.
  1. dvdchild
    dvdchild
    Aug 10, 2004
    4,538
    +153
    Just bought the PWD7 and i was interested in buying the HDMI board (TY-FB7HM). I have a Pioneer 668 that will upscale to 720p. I would like to go higher res even if i had to buy another player.
    But are these hmdi cards limited to what signal they can display as i have checked manual and it appears that it will support all res upto 1080i (correct me if i am wrong)
    At present i have the media box that came with plasma and i am currently using component.
    Should i buy the hdmi board or stick with component. I don't want to waste money.
    All help would be appreciated.
    DVDCHILD
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    the HDMI board only supports 720p and 1080i at 60Hz. R2 DVD is 50Hz (PAL region is 50Hz) NTSC region is 60Hz
  3. dvdchild
    dvdchild
    Aug 10, 2004
    4,538
    +153
    so are we saying don't bother with this board. Can i get a another board that will be suitable.???
    dvdchild
  4. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    i think getting a component board and going direct to the screen will give much better results
  5. dvdchild
    dvdchild
    Aug 10, 2004
    4,538
    +153
    i've got the tuner box which has component on it so i am connected up like this.
    RGB 1 SCart - NTL Digital
    RGB 2 Scart - Gamecube
    Component - Component Monitor output on Denon 3805
    DVD Player - Into Component input 1 on Denon 3805.
    Picture quality is great but i wanted to make use of the HDMI but from what it sounds i'm not really going to gain much. Also concerns me regarding what ratios the hdmi board gives. I just don't want to waste money on something that reaps no benefit.
    dvdchild
  6. dvdchild
    dvdchild
    Aug 10, 2004
    4,538
    +153
    as per horny's quote
    "the HDMI board only supports 720p and 1080i at 60Hz. R2 DVD is 50Hz (PAL region is 50Hz) NTSC region is 60Hz"
    What will happen if you play a Region 2 at 720p/1080i - do you get nothing or a screen full of garbage.
    dvdchild
  7. dvdchild
    dvdchild
    Aug 10, 2004
    4,538
    +153
    just looking at avsales - could i get away with the DVI-D Board and use it with a hmdi > DVI converter. Would i be able to get the res then?????
    dvdchild
  8. FOZZA
    FOZZA
    May wanna wait see what the new Sky HD boxes have got on them.
  9. dvdchild
    dvdchild
    Aug 10, 2004
    4,538
    +153
    just spoke to helpful chap at avsales and he advised stick to the component for the mo until the HDEF stuff starts up properly as no firm hardware connectivity details yet.
    Thanks for all your help anyway and it's just saved me £150 for the moment.
    DVDCHILD
  10. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,785
    Norwich
    +667
    Forget DV/HDMI on a panny screen, it is good, but the analogue in is better, very natural looking.
    What you should do is get rid of the tuner box, it makes the image very soft and really holds the screen back.
    I would get a component input board and a JS Scart->component transcoder and sell the tuner box, and then hook up like this.........
    NTL Digital - into js converter and into component 2 on Denon
    Gamecube - scrap scart and get component and into component 3 on Denon
    Component - Component Monitor output on Denon 3805 into the component on PW7
    You will get a far sharper image and never have to touch the panny remote again.
  11. dvdchild
    dvdchild
    Aug 10, 2004
    4,538
    +153
    sounds like it is gonna cost me more dough now - all i need to do is sell that tuner box and get the other bits then. Anyone wanna buy a tuner box?????
    DVDCHILD
