PW7 HDMI and Panasonic SA-XR70
Discussion in 'Panasonic TVs Forum' started by calmac, Nov 1, 2004.
  1. calmac
    calmac
    Aug 16, 2004
    17
    Hi Folks
    I am considering the above arrangement
    PW7 with hdmi board
    and the Panasonic SA-XR70 - will look at speakers later when budget allows
    Questions for the experts
    When is the hdmi board available or is it available now
    Will the hdmi board accept all the component video standards
    The Panasonic SA-XR70 has hdmi in/out, component in/out svideo etc, will it convert all the inputs to a signal that may be transmitted via the hdmi output to the hdmi input on the display
    Will this sytem be as future proof as possible given my budget restraints £2.5k apart from the SD display - will look at HD in a couple of yrs
    I have at present a freeview box with RGB scart out which will be changed out for a Netgem with component out
    I have an xbox modded with component out and optical digital
    I will be purchasing an hdmi dvd player at a later date
    I cant really be bothered with buying all the input boards for the display (to many cables) and hope I should not have to with the Panasonic SA-XR70
    The Panasonic SA-XR70 has a tuner and appears to be a good quality amp / video receiver for the money
    I wish to stick with hdmi, as this, we anticipate is the way to go - possible xbox2 with hdmi, pc's etc etc
    Any thoughts, comments, restrictions, problems, ideas on the above will off course be very much appreciated.
    Calmac
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PW7 HMDI boards will take a few months suggest you wait it out until the Experts have had a chance to get to grips with them Pannies new S-91 DVD player matches amp perfectly but remember first few amps etc will have very limited HDMI input most are one in one out or 2 in on some top end units
