PW7 Ferite Cores
Discussion in 'Plasma TVs' started by PannyAdams, Dec 27, 2004.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    The Panasonic PW7 comes with a collection of Ferite Cores to attach to any cables that you later chose to plug into it. I have a few questions about these....
    Are they to stop interferance from the cable affecting the Plasma or interference from the plasma effecting the signal in the cable?
    Also, are they necessary if one has high quality well shielded interconnects?
    If so......what shall I do about my flat scart, as they only fit round cables!
    Help?
    Panny
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,181
    London
    +399
    They are there to eliminate RFI interference that you may experience.
    Flat Ribbon Scarts are isolated by design.
  3. 888
    888
    This isn't true. Flat ferrite clamps are also available for the same purposes.
  4. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,181
    London
    +399
    Stand to be corrected but I've only ever used ferrite core on mains cables and not interconnects ?
    Anyway Flat ribbon scarts are isolated (better than shielded) which is why they suffer far less from any kind of crosstalk.
  5. Desticado
    Desticado
    Oct 16, 2000
    1,474
    41
    Canterbury, Kent, UK
    +6
    or you could try taking a quick picture with a digcam/phone and posting it here...
    might help and save a lot of time as you're not familure with a lot of the definitions
