Pw7 Dvi
Discussion in 'Plasma TVs' started by philthyanimal, Apr 27, 2005.
  1. philthyanimal
    philthyanimal
    got a Panasonic PW7, and an arcam DV79. Currently using a mark grant component cable to connect. Would i notice any benefits from using DVI or HDMI from the Arcam?
    Should i get this before an ISF calibration?
    got to say i love the Arcam, it will play disks with horrible scratches no problem.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,998
    +2,802
    Try and borrow a cable and do yourself the demo. There were issues with the DVI board and 576P HDMI out of the Arcam. You might want to confirm that your DVI board is latest spec and works...mine doesn't. If you are going to use the ARCAM in HDMI to plasma then it'll need to be calibrated that way so you should work all this out before having the calibration done...
    Gordon
  3. philthyanimal
    philthyanimal
    Thanks. Don't have a DVI board yet, so it may be a bit of risk buying one.
