pw7 dvd playback problem
Discussion in 'Plasma TVs' started by scotsman175, Apr 25, 2005.
  1. scotsman175
    scotsman175
    Oct 14, 2004
    571
    +9
    i run my pw7 through the panasonic tv tuner supplied by av forums (i know its not the best but all i can afford at the moment)
    my dvd is set up to this as is sky +
    all through scart
    sky + is great
    dvd when i watch films tend to change colour quite regularly or the whole picture seems to move right and then back (only slightly though).
    Very off putting anyone know what i have done wriong here>?
  2. scotsman175
    scotsman175
    Oct 14, 2004
    571
    +9
    can someone please advise me here?
  3. lisag
    lisag
    Jul 14, 2004
    5,557
    Essex
    +296
    I am not the best person to help you here, but any response is better than none!
    Have you tried different settings on your DVD player such as RGB, Composite, progressive - see if that makes any difference? When you say it is an AV Forum supplied tuner does that mean from the classified ads? If so, maybe it is faulty or has some setting changed, can you restore it to default settings?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    is wobble enabled? I cant remeber if setting this with tuner disconnected will still happen when tuner is connected.....un plug the tuner and give it a go........like lisa says does it happen on all inputs, source signals? it may happen on SKy but you dont notice it.....
