PW7 - Connectivity help - RGB or VGA+JS?
Discussion in 'Plasma TVs' started by mh123, Jul 27, 2005.
  1. mh123
    mh123
    Apr 2, 2005
    685
    Offshore UK
    +66
    I've decided to take the plunge and get rid of my PW7 media box.
    I need to connect 3 items to my 37" PW7 and need advice/experiences to decide which is the best route to take. Cost is not necessarily an inhibitor but I can't stretch to any external scalers/processors!!
    1. SKY+ box
    2. DVD player with RGB Scart out
    3. HDD recorder with SVideo/composite Scart out (no RGB)
    The easy one is #3 - I'll use SVideo. That leaves one spare slot and the VGA socket available.
    My plan is to connect the DVD player to the SKY+ box with a fully wired Scart. DVD is secondary in our house to Sky.
    My question is what to do with SKY+. Do I
    a) buy a component card and decent Scart-RGB cable
    or
    b) buy a JS Tech box and run it up the VGA port?
    I'd love to hear recommendations and experiences!
    Also if I did go down the JS route for sky, should I use my spare slot to run RGB directly from the DVD player rather than piggyback Sky?
    Last option I guess is to lose the VGA card and add a second RGB card? Is this a) possible; b) recommended?
    Sorry for so many questions but I need to get this right first time 'cos she won't let me furtle with it again for a while..... :rolleyes:
    Thanks.
  2. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    What are you doing for audio at the minute? there may be another way :)
  3. mh123
    mh123
    Apr 2, 2005
    685
    Offshore UK
    +66
    My DVD is one of those Pioneer models with built-in 5.1 amp and it's actually pretty good, so reluctant to change. Just complicates things, I know! As I say, Sky is main commodity in our house. Sadly. Sky audio is fed to DVD on optical cable. No probs with lip-sync either.
  4. mh123
    mh123
    Apr 2, 2005
    685
    Offshore UK
    +66
    A quick & rather cheeky bump! Sorry if I broke any forum rule but I need to order up any bits & pieces today as next weekend is the big move! :lease:
  5. Mep
    Mep
    Dec 25, 2004
    9,497
    +460
    personally I would go the JS route and connect the dvd directly to the panel
