PW7 connections to Arcam AVR200, DV88+ Help!
Discussion in 'Plasma TVs' started by iranu, Jan 13, 2005.
Tags:
  1. iranu
    iranu
    My father is looking into the Panny pw7 but is confused (as am I :blush: ) as to the best way to connect everything to the screen (preferably with only one connection to the screen).
    Having tried a lot of searching here I've come up with the following
    Sky+ > AVR200 using s-video
    DV88+ > AVR200 using component video.
    AVR200 > pw7 using component video terminal board.
    Is that the best way of connecting the above two with Sky+ box?
    The sky+ box has vga/s-video/composite out.
    Any help will be greatly appreciated. :)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    what you need is a JS RGB > YUV converter into AMP and then conect component from amp to screen
    PS would be first SKY+ box with VGA that i have heard off, RGB yes, S-video yes (modified for SDi yes)
  3. iranu
    iranu
    HD, knew you would come up with somethin'
    Would it be better PQ wise, in your opinion, if a converter is needed, to go
    Sky+ > JS rgb scart to vga > pw7 (as seen in many threads here)
    DV88+ > pw7 using component video. (and component board)
    or should I just do as you command.
    I presume the above removes component switching (if AVR200 supports it)
    btw SKY+ is this one http://www.amstrad.com/drx180.html and has an R232 female DCE which I assumed was for VGA. :suicide: Over familiar with PC's I'm afraid. ;)
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    one cable to screen....(i too assume AVR200 has component switching) all video switched via amp (audio and video switched togethr makes for easier operation.... (there are about 50 different ways to do what you want.....I have suggested, is What is in my opinion, the best for the info you have given me.....
  5. iranu
    iranu
    Brilliant. Ta Very very much for your time and help.
    PS. sry to post in 2 sections but I did need a quick answer i.e. like right now!!
    Much appreciated.
