PW7 component via VGA ? ?
Discussion in 'Plasma TVs' started by Stuart.Ainslie, Dec 22, 2004.
  1. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    119
    16
    Little Clacton, Essex
    I have read that a PW7 cannot display component via VGA whereas a PW6 can -
    Is this true ?
    I am looking at upgrading my DVD player in the New Year to one with component without having to purchase a component input board for the PW7.
    Are there any other options that I can use if this is the case ?
  2. nwunda
    nwunda
    This is correct. I have conected my DVD to the panny via a (component to vga cable), the PW6 did the syncing correctly, but the PW7 does NOT. The screen now has a Green Hue effect. I am trying to get a refund from the shop I bought it from cos they told me that it works. Obviously they didn't check, cos if they did they would have seen that the PW7 is different in this way, it doesn't handle the syncing correctly.
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    If you have a picture at all it is synching, it's the colourspace that's wrong. Just splitting hairs though, it doesn't work does it. The box to change it is there in setup, it's just greyed out.
