PW7 Component/RGB to optional VGA board
Discussion in 'Plasma TVs Forum' started by blackmanalishi, Feb 28, 2005.
  1. blackmanalishi
    blackmanalishi
    Hi all,
    I've been offered a pretty cheap VGA terminal board from my PW7 (which I believe will accept Component unlike the native VGA board), however what I'm not sure of is whether I would need a converter to have RGB going into it (from Sky+), or indeed whether there are any other options.
    I have found numerous websites selling SCART to VGA leads, and the seller has told me this should work, but I have a nagging feeling it's not that simple and I'd like to know for sure - and the reasons why.
    Alternatively I could put my Xbox through the new VGA port if I could find a connection to suit it - again, do I need a converter and if so why? I already have SCART, Composite and Component leads for my Xbox.
    Thanks in advance...
    Also,
  2. blackmanalishi
    blackmanalishi
