PW7 Component Boards?
Discussion in 'Plasma TVs Forum' started by turfmonkey, Jan 22, 2005.
  1. turfmonkey
    turfmonkey
    Sorry to create a new thread but my Panasonic TH42PW7 is coming tomorrow and I still havent resolved what board I need. it comes with a scart as standard but for my set up I think I need a TY-42TM6V Composite/S-Video board. My setup will have a Yamaha Amp with Video Switching, Sky + and a DVD. With this setup i was hoping to run the 3 core composite cable from the plasma to the amp and switch input device to the plasma from the amp - is this possible or is there a better solution.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try a search mate i think you mean component.....will need a component board.....(good luck)
  3. Peabo
    Peabo
  4. turfmonkey
    turfmonkey
  5. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    second option........component.
    how are you connecting up the sky+ though - scart obviously...doh
    cheers, tam
  6. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
  7. Sparkster101
    Sparkster101
    Jan 17, 2005
    65
    11
    +4
    Component is much better quality although you need to make sure you have something that can send a signal as component to the plasma. Do a search of this site as theres loads of information on this subject.
  8. rizingdamp
    rizingdamp
    When Horney replys with "Good Luck" what he maens with regard the PW7 component video board is simply that there are a distinct lack of them in the country!!
    I myself have contacted Panasonic UK and thier response is ....."not sure when they will be available"
  9. Sparkster101
    Sparkster101
    Jan 17, 2005
    65
    11
    +4
    You can get the dual boards though, not sure what the compromise is apart from board space.
  10. turfmonkey
    turfmonkey
    I havent got the amp yet, but will be getting this week, the plasma arrived today. My initial thoughts based on what I have read about the Yamaha RXV650RDS amp is that I would use it basically as a hub to switch between input devices and the amp would output video to the plasma and sound to my 5.1 speakers. this is what I wanted to do but was unsure of the feasibility but thought the solution would be the component card. I have a scart board that came with the screen but didnt think of it as an option - can you advise if this is sensible or am I misguided.......bit of a novice really! :clown:
  11. dempsey
    dempsey
    End of Feb as far as I have heard.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no loss of quality on component using dual board (get an S-video/composite input as well)
  13. d0mj4y
    d0mj4y
    Dec 25, 2004
    130
    Norwich
    According to what I've heard from Panasonic, a container full of them sank as they were being shipped over here.
