PW7 box size?
Discussion in 'Plasma TVs Forum' started by Pezerinno, Mar 22, 2005.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    Hi, could someone please tell me the dimensions of the 42" panasonic PW7 panel box as I want to know if it will fit in the car.
    Also has anyone transported a plasma in your car on longer journeys? I won't go into detail but mine will have to be transported 120miles twice a year - due to this should I perhaps not buy one?
    Has anyone sent plasmas via courier? if so what sort of price are we talking?
    Thanks.
  2. c_fletcher
    c_fletcher
    Reckon its approx 120cm wide by 90cm high by 40cm deep but I can measure it exactly when I get home if you like
  3. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    You probablly know already but plasmas have to be kept upright at all times otherwise you will damage them.
  4. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    thanks for the replies - yep am aware it has to be kept upright :)
    Fletcher if you could get exact measurements that would be much appreciated.
    Have you tried transporting it in your own car? It would be going in a average sized saloon. The width and depth should be ok but am a little anxious about the height.
  5. JulianL
    JulianL
    How many other people need to go in the car? If I end up getting a PWD6 from Richer Sounds then my plan is to put it on the back seat, pull the 2 rear seatbelts across the front of the box and probably tie the two buckles together in the middle since I won't be able to get to the clasps, and then stuff a rolled up blanket between the back of the box and the seats to make sure the box is sitting vertically.
    - Julian
  6. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    if a plasma has to be kept upright all the time how do you fit the boards into the panasonic ones ?
  7. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    i fitted my board when it was up on the wall. a little bit tricky getting the screws in but got there in the end.
    i would say it would fit on the back seat of an astra/focus sized card.
    Dal
  8. hermanmunster
    hermanmunster
    Dec 23, 2004
    499
    Somewhere sunny and warm...I wish
    +24
    Will definitely go in the back of a Focus Estate, also on the back seat of a Mondeo (newer shape) hatchback....from personal experience. :)
