PW7 - Automatic progressive and interlaced source detection?
Discussion in 'Plasma TVs Forum' started by flexiondotorg, Mar 21, 2005.
  1. flexiondotorg
    flexiondotorg
    Nov 15, 2004
    232
    Hampshire, UK.
    +6
    This is probably is simple question but something I have overlooked during my demos of the 37" Panny plasma (TH-37PWD7).
    Do these screen automatically detect interlaced and progressive sources from the inputs and then handle them appropriately? Or, do you configure an input to only handle a specific type of source material? I am guessing it will auto detect, but I would like to know for sure.
    Thanks in advance.
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    the screens are prog scan anyway and unless you have a £500+ dvd player will most likely do ps better than source.
  3. flexiondotorg
    flexiondotorg
    Nov 15, 2004
    232
    Hampshire, UK.
    +6
    I think this helps. You are saying that regardless of source format the PW7 will display the video progressively, which infers that these screens do auto-detect interlaced material and convert it?
    I am considering a scaler, not sure if I will do this from the outset or at a later date. Hence the reason for my question, if I do not go for the scaler now I wanted to be sure my multiple connections in to my A/V receiver will work when up-converted to a single component out going to the plasma.
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yep that's what I'm saying :) save money on scaler for later date if you feel you need it.....the experts here would recommend going for professional calibration when you get the scaler
  5. flexiondotorg
    flexiondotorg
    Nov 15, 2004
    232
    Hampshire, UK.
    +6
    I have already budgeted for ISF calibration :) Due to the reduced number of cables, converters and plasma boards I would need to buy if I use a scaler, the cost difference is of using a scaler is ~£200 more than routing everything through the A/V reciever and up-converting. Over the total cost of the new system this is "small change", but I wanted to understand the interlaced/progressive handling piece anyway.
    Thanks for answering my questions.
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    which scaler are you looking at out of interest?
  7. docb
    docb
    Nov 22, 2004
    253
    I am thinking along the same lines, and looking at the Lumagen scalers.
    They seem to be the "best" of the bunch for the money, but actually seeing one in the flesh seems very difficult.
    Does anyone know anywhere around yorkshire where they can be demo'd, and if so if other scalers can be seen side by side?
    Sorry for highjacking the thread...!!
  8. flexiondotorg
    flexiondotorg
    Nov 15, 2004
    232
    Hampshire, UK.
    +6
    After seeing several DVI/HDMI vs. Component comparisons at various dealers with various hardware I have concluded that using DVI/HDMI connections doesn't yeild sufficient quality imporvement to warrant the extra expense. Please don't flame me, it is just my opinion and a generalism.
    That said, the CinemaTeq Picture Optimizer looks like a suitable solution for my minimal setup.
    http://www.cinemateq.de/index.php?content=e_2_1_5_0
    I am planning on running everyting into my A/V receiver as interlaced, then running the up-converted component out from the receiver to the CinemaTeq component input, then out from the CinemaTeq via VGA and into the built in VGA input of the PW7.
    The VGA output from the CinemaTeq can be configued to RGBHV, RGBS, RGsB or YUV. I just need to find out if the PW7 is compatible with at least one of those...
  9. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    well as the js tech rgb to vga converter outputs rgb with H&V seperated it should be fine I would think
  10. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    that seems to be one of the favourite quotes from a certain dragon :rotfl:
  11. flexiondotorg
    flexiondotorg
    Nov 15, 2004
    232
    Hampshire, UK.
    +6
    I have looked at the JS RGB to VGA converter, I don't think I need it for what I am proposing. Isn't the JS RGB to VGA converter Scart in VGA out?
    If so, it would not fit my requirements as I would have component out from my AVR which goes into the scalers component in. The CinemaTeq scaler only outputs on VGA but can be configured to use a number of different color spaces.
  12. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    :D yes it does look familiar doesn't it!!..but also true based upon my experiences so far :smashin:
  13. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    what i meant was the js puts out the same signal to vga that your scaler does
  14. flexiondotorg
    flexiondotorg
    Nov 15, 2004
    232
    Hampshire, UK.
    +6
    OK, thanks for the clarification.
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Hiya Martin,
    You need your scaler before ISF, or you will need it done again, and with all due respect to Gordon, I think the scaler will make more difference, and in fact multiply it's usefulness with ISF, I'm sure Gordon would rather work with a scaler than without. The Cinemateq is probably the least favoured scaler on the forum, most have DVDO or Lumagen. Looking at the spec, this is probably because they have more inputs as well as more retailers, and I believe, a more professional and adjustable interface. My thoughts, FWIW, you should probably look at an HD screen, then get the scaler later, then the ISF. You could then go component via the amp for all component or s-video sources, and any RGB scarts, ie sky etc, RGB to VGA, then sell the vga box when a scaler is possible. Just another way of looking at it, others will have different views!
  16. flexiondotorg
    flexiondotorg
    Nov 15, 2004
    232
    Hampshire, UK.
    +6
    Hello again :)
    I realise that I need ISF when both scaler and plasma are in place. No probs there. I also appreciate that the CienmaTeq is not as popular on these forums as the DVDO iScan HD/HD+. I have not ruled out the DVDO iScan HD completely, but for £529 the Cinemateq is more affordable and while offering minimal features, it does do everything I would need.
    While I would love an HD screen, it is probably beyond my budget at the moment. I will have to do some price comparisons when I have finally settled on the other equipment and connections.
    I think I am right in saying that the standard definition Panny plasma can accept 720p video? I do realise that they are not high definition resolution, and will downscale the video. So long as I have this right about SD screens working with 720p video, then I think it is suitable for my viewing requirements at this time and certainly within budget.
