Pw7 37 connections
Discussion in 'Plasma TVs' started by Baron Von Doom, Apr 27, 2005.
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    I got a pw7 a couple of weeks back with the tuner box. At present everything is connected to the box. dvd via componant, sky and dvd rec via scarts, pc via vga on screen.
    i am now wanting to use the picture in picture and other disabled features so want to get rid of box
    Will there be any difference in picture quality?
    What is the best way to connect to the screen?
    How much is this likely to cost?
  2. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    anyone
    Also lip sync is way out on dvds. Amp cant be adjusted any more. Do these delay boxes work and do they effect sound sound quality
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    so you have: DVD, DVDR, Sky and PC?..what amp do you have?
  4. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
  5. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    does that have component inputs like the 450?
  6. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    no only single phono input for video presumably composite
  7. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    well i would connect via component board (bnc is much cheaper than the rca). use a component switcher so that you can plug both dvd and dvdr into that..and switcher to the screen..you can get component board for about £60...and js do teh component switcher box...about £55
  8. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    Also noticed component seems to be a lot darker than scart. Using monster3 scart and thor component
    does the tuner make any difference to picture quality
  9. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    i think it does...haven't used one...but from what i read here it pretty much buggers everything up!
    there are quite a few options really...sky to vga via a js rgb vga converter is great..but you have pc going in...so would need a way of switching vga iputs......scart board is not bad but many complain of a soft picture....upgrading the amp gives some more options too.....even the rxv 450 for just £150....gives you component switching and much improved audio delay
  10. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    Does anyone know know how much delay the 450 gives??
  11. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    yep...up to -160
  12. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    Thanks for the help mep will prob see how much i can get for my rxv350 then go for a 450
  13. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    superfi are doing them for £150...rrp = £300
  14. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    do they have a web site
  15. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
  16. is1111
    is1111
    Mar 17, 2005
    1,281
    48
    +98
    just to add regarding the rxv450. i got one from superfi and it was received in a couple of days. bought online and got emails updating the order status and you can also check online.no complaints about their service if you are thinking about getting one and amp is great for the price.got mines hooked up to canton cd1's and well happy.
  17. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    Whats Picture Like Through Component Conection. Does It Effect The Picture Quality
  18. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    component gives excellent pq but running it via the amp wont improve it...
  19. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    i dont want it improved. Just wondered if it effects it at all. is it easy to use the delay. my rx-v350 wont let me delay more than about 25ms
    thanks for help
  20. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    ok, just thought i'd mention it......the delay is very easy to use...just an option in the sound set up menu and as i say it does upto -160ms which is more than enough...it's a really good amp for the money i reckon
  21. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,524
    worthing
    +140
    Thanks for the help. will probably upgrade soon. just to confirm it lets you go straight to 160 ms as mine wont let me hit the 99 as the manual says
  22. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    yes you just set it wherever you want it in increments of 1ms
