PW6D > Goodnight?
Discussion in 'Plasma TVs Forum' started by PTG, Dec 16, 2004.
  1. PTG
    PTG
    Afternoon :) Has anyone done or know the "codes" and how to put the PW6D on and into standby mode from the Sky+remote.
    Cheers very much :thumbsup:
  2. The Nightfly
    The Nightfly
    Aug 31, 2002
    821
    The New Frontier
    +24
    Use the code published in the Sky user guide for Panasonic. 051 if I remember correctly. Works with my 7 series panel.
  3. PTG
    PTG
    Thanks mate :smashin:
  4. Senrap
    Senrap
    Nov 19, 2004
    126
    London
    +8
    PTG, I am not sure if that is the correct code; if it doesn't work call Sky on the Technical support number and they will set you up in 30 seconds flat...that is once you've spent 5 minutes going through the damn menu to get to a human being!
  5. Senrap
    Senrap
    Nov 19, 2004
    126
    London
    +8
    By the way, don't waste your time trying to go interactive as the voicemail will try and suggest when you get through to Sky.
  6. Akuma_uk
    Akuma_uk
    Dec 15, 2004
    7
    Allan,
    I have just bought a PW7, but I can't get volume punch through on my Sky+ RCU.
    Can you? And if so what code did you use.. I've tried 051 but it doesn't work.
    When I push 'TV' on the Sky RCU the up & down Nav buttons control the volume!?
    When I push 'Sky' I still can't use the volume buttons.
    Any Ideas?
  7. The Nightfly
    The Nightfly
    Aug 31, 2002
    821
    The New Frontier
    +24
    Akuma,
    That doesn't sound right. I've just looked-up the code that I used and it was 0051
    With this code entered into the Sky remote I can use the Vol up/down buttons and the mute button quite normally to control the plasma and the Nav buttons have no effect on the plasma. I don't have to be in 'TV' mode on the remote to control volume or mute - it always works regardless of mode. By using the 'TV' mode on the remote I can put the plasma into standby or wake it up.
    Have you programmed the code into the remote using the sequence described in the digibox user manual ?
    Allan
  8. Senrap
    Senrap
    Nov 19, 2004
    126
    London
    +8
    Akuma, try this.
    Point rcu away from sky box and press tv.
    Then press red button & select together and red light should flash twice.
    Then type in 678 and press select.
    It worked for my PW6 and will hopefully work for the PW7.
  9. Akuma_uk
    Akuma_uk
    Dec 15, 2004
    7
    Hey,
    Thanks guys.. I tried typing all the 3 digit codes from the Sky Help page
    and also the general 4 digit Panasonic code (0051).
    Gave up, :suicide: ,called Sky and they told me to do the following..
    Instead of the usual 3 digit codes, use 999. This resets the remote to the
    factory settings.
    I then used the 678 code, which, as you rightly said, works a treat!! :clap:
    So there you go.
    Cheers!!
    PS: Is there a way on this forum to search for threads I've posted in?
  10. SShaw
    SShaw
    Advanced Search - search using username
    Scott
  11. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    Easier way than that - click on your username>view profile>find all posts by *insert username here*
    You can do the same for any user
