pw6b & humming
Discussion in 'Plasma TVs Forum' started by john R1, Dec 5, 2003.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Received pw6b yesterday well happy with pq from telewest digital via scart & dvd via component, not so happy with the humming come buzzing, had a slight hum on my previous 37" pw5, but this is much worse, will it get better or should i insist on a replacment straight away, any thoughts,
  2. sunil4
    sunil4
    Insist on a replacement. Not quite relevant but i got a 36" top of the range panny CRT screen about 5 years ago from Comet at £3.5k at the time.
    The transformer hum was too much plus the distortion of geometry at the bottom rhs of the screen (when a banner comes on) put me right off - told them to come and collect it and give me a refund - which they did promptly after their free call out engineer confirmed the symptoms
    I bought a Tosh instead
    Now thinking of buying a Panny or Pio plasma so hey hum!......
    Get it replaced anyhow - it will only wind you up if you dont!
    cheers
    S
  3. gpa
    gpa
    This does seem to be a fault as i have NO humming on my screen at all, get it changed.
    cheers
  4. DucatiEVO
    DucatiEVO
    My screen (pw6) is dead silent too, I'd get it changed!
  5. clouseau
    clouseau
    Just to add to the last posts.... it seems you have a problem as my P6 is silent.... sorry !!!
  6. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Humming is now more a quite buzzing, its there on both telewest digital via scart & dvd via component, strange thing is it varies depending on the broadcast being received phoning shop again monday to see about my replacement
  7. DucatiEVO
    DucatiEVO
    Does it buzz on it's own with no input and nothing plugged into it? This would tell you if the screen is at fault. Could be a noisy signal causing the buzzing maybe?
  8. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    yes there is hardly any buzzing with no signal going into it, but surely plasma does not need to pull any current until it has to display an image, so dont see your point
  9. DucatiEVO
    DucatiEVO
    Me neither now, please excuse my lame attempt at fault finding and I'll go back under my stone. :(
  10. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    DucatieEVO sorry about my abrupt reply, but having looked back through old postings on this problem have not found any real answers john R1
  11. DucatiEVO
    DucatiEVO
    no worries mate :smashin:
    Best bet it to take the sucker back to be replaced and be done with it! Hope you get it sorted out asap.
  12. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Have just spoken to the shop they will be replacing set either sat or tue-wed next week, so hopefully only have to put up with buzzing for a few more days, next problem will be trying to get the stickers for scart & component boards as i have stuck them on this one, only a minor thing compared to the buzzing
