pw6
Discussion in 'Plasma TVs Forum' started by fitz62, Mar 15, 2005.
  1. fitz62
    fitz62
    whats the best settings for the pw6?,on some dark films the blacks really do look very black indeed,distorted a little. any advice
  2. SNICK
    SNICK
    Feb 4, 2001
    793
    28
    UK
    +29
    The quality of blacks on a PW6 is a one of it's strong points :) unlike some other brands where black looks a bit grey :eek: - have you tried playing around with the picture settings :confused: or are you using the media box?
  3. fitz62
    fitz62
    ive got it going into a daewoo box , but i can also play around with the pic setting at the moment there factory set
  4. Brooktop
    Brooktop
    Feb 2, 2005
    2,141
    Nottingham
    +102
    From RS no doubt???!!!!
    Oh dear, you're in for some stick!! :lesson:
