PW6 VGA-Component
Discussion in 'Plasma TVs' started by hornet, Sep 6, 2005.
  1. hornet
    hornet
    Apr 15, 2004
    325
    Hayes Middlesex
    +7
    Hello
    I was just wondering about the VGA input in on my PW6 panel, I know that it is able to accept a component signal, and I am currently feeding it an RGB (sky+) signal from a RGB Scart to VGA converter.
    I am quite sure that the converter can output a component signal and I would really like to use this so that I can make use of the extra colour tweakability it will provide my sky+.
    What I need to know is, are there any setting I need to change to make this work? (Hidden menu)
    Or is there another device that I need to purchase to make this work?
    Dav.
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Yes, your VGA converter will not do component, you need a different box. Setting the port for component is very easy, it's in the 1st setup screen, top of the list.
  3. hornet
    hornet
    Apr 15, 2004
    325
    Hayes Middlesex
    +7
    Nice one MAW, but what would this extra box be?
    Dav.
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    JS RGB to component box naturally!
