pw6 sky + codes
Discussion in 'Plasma TVs' started by rab4169, Jul 6, 2005.
  1. rab4169
    rab4169
    Dec 12, 2004
    533
    just got my pw6 up on the wall today but can`t get sky remote to work with it . have tried the forum but all i see is the code 0051 which won`t work it.
    anyone know the code
    cheers
  2. Enquirer
    Enquirer
  3. rab4169
    rab4169
    Dec 12, 2004
    533
    still nothing,sorry
  4. Enquirer
    Enquirer
    Ive tried that code and it normally works what are you trying to control other than power and volume?
  5. rab4169
    rab4169
    Dec 12, 2004
    533
    press red and select ,blinks ,type 678, try vol and off but nothing
    is this right?
  6. Enquirer
    Enquirer
    1. Press tv on your Sky remote control.
    2. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    3. Key in the three digits code 6 7 8 ; the red light on the Sky remote control will blink twice.
    4. Press tv and try the handset
  7. rab4169
    rab4169
    Dec 12, 2004
    533
    sorry to be bumb but is 678 the "direct code"
    i press select and red ,flashes twice , i type 678 but does not flah is there another code i put in before 678
    thanks
  8. Enquirer
    Enquirer
    yes its a direct code .
    try this
    1. press the TV button on the sky remote.
    2. hold down the red button and select for about two seconds until the red light on the Sky remote control blinks twice.
    3 key in 6 7 8 then press the select button
    4 press the TV button and test that it works
  9. rab4169
    rab4169
    Dec 12, 2004
    533
    thanks will try in morning , upstairs in bed now on the laptop
    cheers
  10. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    excellent - work on my pwd6 - thx guys
