PW6 Scarts
Discussion in 'Plasma TVs Forum' started by novaya_zemla, Sep 26, 2004.
  1. novaya_zemla
    novaya_zemla
    Hi Guys - First off I would like to say thanks to you all for the fantastic information available in these forums which convinced me to buy a Panasonic TH-42PW6 from Digital-Point (great service) Having just blown my entire budget I now need to get my pioneer DCS313 (with slightly modded rear fan) and my Digital Freeview box into the plasma through just one scart (TY-42TM6T) My old Maplins two into one with a switch is frankly rubbish and left nice horizontal lines across the screen so that was quickly ditched - I get the sound out OK but am a bit snookered as to how best to get the DVD picture in alongside the Freeview?
    Can anyone help with a short term -Cheap- suggestion?
    PS - I am in the market for any old TM6T's you might have lying around...:thumbsup:
    Thanks :thumbsup:
  2. bongpig
    bongpig
    B-Tech make the Quintro and Triton scart switchers.
    Many peeps recommend the Quintro, which can be gotten or around £60-90.
    The cheaper Triton can be found for under £30 if my memory serves me correct.
    look here:-
    http://www.b-tech-int.com/Welcome.html
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    which Freeview box as short term you can daisy chain scart from DVD>FV>plasma if you have 2 scarts on FV, Pana TUCT30, Humax PVR800T etc
  5. novaya_zemla
    novaya_zemla
    Quintro it is then - Thanks for the quick advice.
    Having just typed quintro into the search function I see that my question has been answered about 20 times over the last few years! :D
  6. novaya_zemla
    novaya_zemla
    Hang on a minute! - hornydragon you are a star!!! I thought my Goodmans GDB2 scarts were 'out' only and pass thru wouldn't work. Not only does it work - but it's perfect.....
    Thanks again...
